Matthew said:so is your setup coming from the bottom or do you have a straw? i dont have a straw yet, so i cant install it right away...what place is it leaking from exactly again?
Pirana said:
Bijou, if you want to, send me yours back. They do have more blue ones, so I could get it exchanged. Is up to you. I didnt look at them since I just popped the top to put the tube. I guess I will look at these ones more closely. But if you want to exchange it, let me know.
Pirana said:Are your fittings cross-threaded? If thats the case, you might want to remove the fitting, and see if they go in straight. I'am looking at one right here, and thats about the only place I can see for a defect. Like I said, since I got to go and pick more of them, if you need it exchange, I dont think there is a problem. If you want to use a sealer, just use clear silicone. But I would remove the fitting to seal it better.
Pirana said:Tonka and others that havent installed your cans, might want to wait for this fitting to arrive to you. Since to install this, you need to empty the can. This will eliminate the "straw" and will work better.
