Sorry to bump a somewhat old thread, but better than creating a new one IMO...
I attempted to just replace the dust boots (on top of the ball joint) I broke when I did my wheel bearings about 5-6 months ago...
Those suckers were NOT cheap through my local dealer (should have ordered them online) anyhow, I greased them up and used the axle socket to snap them on top of the ball joint.
However, when I put the hub back on maybe I pushed it too far down onto the ball joint? I thought I put them back where they were when I removed them, but in doing so I basically trashed the new dust boots I had just paid a pretty penny for. Knowing the other bushings and ball joints themselves were probably about done anyway (car had 220,000 then, just rolled 225,000 last week) I just went ahead and put the car back together...
No problems because its been a fairly dry past 5-6 months but now I'm having some noise in the front (popping, etc) and when replacing one of the ouput shaft seals on the transmission yesterday I saw just how bad those dust boots look. Its been a very wet past couple of weeks here in Memphis, so I'm pretty sure the ball joint is probably done...
So the point of my question/post is, when I replace the lower control arms (I'll probably go with the $150 shipped pair off of ebay) how far do I sit the hub onto the ball joint? Is that groove in the ball joint for the bolt behind it? That would be a decent referance point for where it needs to be and if that is the case, I bet I did put the knuckle down too far on the ball joint. If I recall correctly, its been 5-6 months, the ball joint popped up out of the top of the hub/knuckle maybe an 1/8-1/4 of an inch?
Any special tools I'll need for the job?
Thanks for any help, wow, that turned into a book, ha...
I'm still probably a few weeks out from doing this project, but I need to get it done before I start back to school...
