Captain KRM P5 said:
i am of the mindset that having some backpressure is good, that losing too much of it will rob you in the end of some power, so in my opinion there is no need to go any bigger than 2.5 inch on a catback exhaust system, and then only if you have a turbo. i have seen a few proteges running around with a 3 inch which i think is a little extreme. on an "all motor" setup 2.25 would be great. what really hinders our exhaust systems is a pair of restrictive catalytic convertors and a weenie midpipe.
my advice on a setup like this is to scrap the stock exhaust manifold and first cat, replace with a header, slap on a decent 2.25 catback exhaust and find someone who can make a good midpipe for you and thats my recipe for better protege breathing.
I was of the same belief. Then I was hit with this nugget from Installshield.....
<TABLE class=tborder cellSpacing=0 cellPadding=6 width="100%" align=center border=0><TBODY><TR vAlign=top><TD class=alt1>It is misleading to refer to backpressure as any type of benefit to any engine, and it is honestly incorrect...
Backpressure is any inversely directed pressure gradient within the exhaust system...and it usually forms around bottle-necks or restrictive kinks in the piping...Now it does nothing but hurts power and torque, and can even cause detonation problems as well as poor fuel efficiency...It is no ones friend...
Just as a little intro to exhaust theories, to anyone that is unfamiliar with it: It is said that exhaust gasses travel as pressurized pulses through the piping, and out of the car...The diameter of the said piping is directly correlated with the velocity the individual pulses travel through the system...The bigger the ID, the slower the velocity...and vice versa...at a given rpm...
Sadly high-end hp and low-end torque do not agree on a perfect internal diameter...At maximum volumetric efficiency, which is where an engine makes maximum torque for the most part, results in huge individual pulses...and these are usually occuring at a relatively low rpm compared to redline...at these engine speeds maximum torque is created when these individual pulses can travel extremely quickly out of the exhaust system, and literally make a vaccum pulling combusted gas out of the engine, and fresh air in (that is scavaging, and the complexities of that are beyond the scope of this)...So overall a smaller ID results in a stronger pull at low rpm...and a whole ton of people claim that this is caused by backpressure...I assure you it isn't...
but on the other hand, apply this to high rpm hp output..pulses at this engine speed are relatively smaller, but there is a lot more of them (Crazy car dorks refer to this as "pulse frequency")...and despite getting smaller, they end up bouncing off of each other and searching the exhaust system for any blemish, kink, bind, or restriction that they can...and they are good at it...the solution is to use a bigger ID for the piping...with a smaller ID, hp output usually suffers due to choking affects...
So you can see where this is going...Some dudes like to grab a 3" exhuast for a 2.0L engine, because it sounds cool when they tell there friends that...But it is way too big for lowend torque, and unless there 2.0L can rev to 11grand...it will never make enough pulses to get anywhere near hung up (honestly that is bad example because an exhuast of this size would never promote fast pulse velocity, and would overall kill output everywhere...not just lowend torque)...
But again backpressure is simply a pressure "wave" pushing towards the engine, rather than pulling exhaust pulses out...and it always makes for more strenuous exhuast strokes in the engine and very poor breathing, and overall hurts engine output...
So finding an exhuast with a good ID for both is the best bet...a little on the large side promotes better topend output...a little on the small side gives better lowend torqu, with a little less highend output...and the extremes are decent as long as you are not over them...For NA proteges trying to stay streetable, I would put a ceiling at 2.5"...and that would be reserved for some pretty highly modified FS's...
<!-- / message --><!-- sig -->__________________
"I am a Union Delegate" -Henry Hill '63
<!-- / sig --><!-- edit note --><HR style="COLOR: #d1d1e1" SIZE=1>
<!-- / edit note --></TD></TR><TR><TD class=alt2>
</TD><TD class=alt1 align=right><!-- controls --></TD></TR></TBODY></TABLE>
