Completed system wiring this weekend...
I worked on the grommet again this weekend, and managed to get the amp power wire thru it, and pop the grommet back on. I feel much better now, and there is no hole in my firewall anymore!! (2thumbs) (Well, wasn't really a hole, but when the grommet wasn't in there was a hole of sorts...) Now I just have to work on mounting the amp rack to the back of the rear seats...or on a hinged assembly attached to the floor. Is there anything right below the floor behind the rear seats? If I end up screwing thru the floor, I don't want to mess anything up... (boom02)
I would avoid drilling holes in your floor. A better approach would be to utilize the exisiting bolts (e.g. the cargo net tie-downs). If your amps are small enough, you might be able to fit them under the front seats.
