Comparing 87 to 91 octane for the 2.5L non-turbo engine
erhayes
Contributor
2022CX5 PP
Is there any data that compares 87 to 91 octanes for the 2.5L non turbo charge engine. Just curious. Ed
If the owners manual doesn't specifically say you need to run 91, than 87 will be perfectly fine.
The only thing the higher octane rating does is prevent knock and pinging.
I noticed no difference in power or fuel economy while running a couple tankful's each of Premium, and alcohol free gas through my 2015 Touring. Save the extra dollars, stick with regular.
Alcohol free should have gotten you better gas mileage. Real gas burns with more BTU's per ounce than mix does, so the engine wouldn't have to burn as much to maintain the same speed.
mazda now claims 91 is recommended. In the past I dont recall such recommendation.
dont know why. My experience with 91 and CX5 NA is that the car felt more responsive in then summer heat but that may be subjective.
What is objective is that the knock/retarding of advance was better with 91 as monitored form the obd. But that doesnt mean it wont run on 87.
Alcohol free is best if one can find it nowadays.
Maybe not important for consideration but I notice with all my cars anytime I look at aftermarket power enhancing parts that show a DYNO result most are always stipulating using 91-93 octane gas.
mazda now claims 91 is recommended…
Where is this recommended by Mazda?
Very interesting how they listed the fuel recommendations. Makes for what could possibly some long debates about really what fuel octane to use. I will personally just stick with 91-93 unless not available where I would be driving.
This is true but...
Unless you drive like a grandma , soft on pedal, flat roads, and all highway miles, and you actually track you mileage and calculate your mpg than most people will not notice the difference.
How you drive, f.i. stomping on the gas pedal will affect your mpg far more so than e85 versus the real stuff.
Also some top gasoline e85 performs better and may only be a slight decrease in mpg when using certain brands.
So e85 will always get less fuel efficiency but overall, you may not notice much depending on your driving habits. The OP probably hasn't noticed much difference because other factors affect mpg as well.
And at the end of the day, the e85 should be cheaper so $$ wise, it all balances out.
It soon won't matter as real gasoline is quickly becoming the elusive purple unicorn.
There is no real gas on my commute to work and to get pure gas for my lawnmower requires traveling 30 minutes (out of my way) in opposite direction from my house. If this station stops selling pure, will be hard pressed to find another location.
... There is no real gas on my commute to work and to get pure gas for my lawnmower requires traveling 30 minutes (out of my way) in opposite direction from my house. If this station stops selling pure, will be hard pressed to find another location.
It is possible to remove the ethanol from the fuel yourself as needed for your small engines (or any engine) fairly easily. All you need is a container, some water and a way to drain or siphon off the bottoms. Add water to the fuel, shake it up, the ethanol absorbs the water and separates out dropping to the bottom. Then drain or siphon that out and you now have 100% pure gas :)
You can also use the same procedure to test what percentage of ethanol is in a fuel, if any.
To OP:
You're going to get furious debate on here about this issue. You'll get all the pseudo scientists trotting out all the documentation in the world showing that there is no difference in using 87 vs. 91.
Then you'll get all the pseudo scientists trotting out all the documentation in the world showing that 91 vs 87 is better.
Go with what you feel and experience as neither fuel will damage your vehicle.
My experience is that my 2017 CX-5 runs noticeably better on 91, and even better on 94 octane fuels. I also get approx 50kms more distance per tank. That's my experience.
Do what YOU feel is best. It is YOUR vehicle after all.
100% pure gas? What happens to the water that isn't absorbed by the ethanol?
After you put water in the gas, the ethanol binds harder to the water than the gas. Then you decant off all water/ethanol mix, leaving just the gasoline behind.
This is true but...
You seem to be talking about e85 as if it's the 'normal' ethanal laced gas at the pump, it's not. Check the pumps, there's 'normal' ethanal laced gas (~10%) and then there's e85. In most cases (if not all) the engine has to be designed/tuned to run on e85.
Right, because E85 is corrosive, and it only has a greatly diminished power capability per ounce of fuel compared to gasoline.
Understand that higher octane numbers absolutely does NOT mean more power. This is often misunderstood. The only thing higher octane does is reduce knock and pinging, which allows you to change ignition timing. The timing change can effect power, but not nearly so much as to offset the power losses of running ethanol vs pure gasoline.
Where do you get your information from? I realize that you may think this but every performance ECU tuner in the world has warnings for using some preset ECU tunes for use with 91 or 93 octane fuels or chance causing engine damage. I do believe that you would be hard pressed to find forums that guys show their best DYNO results using anything but 91,93 or higher-octane fuels. So I am wondering if this is a personal belief you have or something you read? I do agree that this is so often misunderstood.
The Predator 2 Platinum, PN 7210, does include custom tuning capability and additional power levels for 93 octane fuel on some applications.
93US/98EU Octane tune for CPE CAI and Corksport catless race pipe. !!! HPFP upgrade required !!! 6900 rev limit
There are countless more, but I will say these are all performance references. I will support that if you drive without a load factor to any degree and live in an area that is for the most part flat and the temperatures seldom vary between 45F and 100F throughout the year then I can see the reasonable choice not to use -91+ octane fuel.
On the subject of small engines and octane of using oxygenated fuels, just add Xylene to the gasoline you use it will up the octane and run cleaner even if you use fuels from say Kalifornia. ahaha!
