Laser03pro said:I just called the dealer this involes the ECM reprograming and a inspection of the VTCS. My problem has to be the ECM program and the only thing it could be since is the ECM is advancing the timing to much at initial start up and causing predetonation. The ECM really doesnt do much but control the fuel and timing.
GlowstickNinja said:Anyone have the info on the TSB for the MP5 Wind noise? I tried following the links but they don't work. thanks yall.
TheMAN said:it's NOT the timing advancement and there is NO engine damage involved although it sounds like it
the sound is coming from the VTCS butterflies... it's just swirl control shutter valves at the end of the intake manifold runners... the ECU pulses them opened and closed rapidly when the engine is cold and the metallic noise you hear is the result
