red95_240sx
nope all you have to do is move the batt. back, and kinda compress the tube at the flex part. works great
steve_protege said:You used your stock MAF, right? Haven't had to modify it in anyway?
mazpro said:yes, I have the stock maf with no modification. I used to have an eBay CAI and it ****** my maf, so I got a new one from the stealership (which was 125!!) and that is what I am running right now with no modifications
Protephile said:Let me know if you want that Saab intake. I'm on my second order. I'm just not selling them on your Saab forum.
french02chris said:to PROTEPHILE : do you recommend any header for 1.6 protege..the only thing that i can find is the OBX??
thank
ducktape said:-------sorry if this is not in the right thread----------
i dont know if you guys that have problem with hesitation with cold air intake on protege 1.6l ??: i had this problem too since i installed it, here is the solution :
the MAF is mostly the cause, but hes doin his job ok. it calculate the air flow that passes in the pipe and tells the ecu how much fuel to pump in engine,
since the stock intake pipe ( rubber one) is smaller (diameter), when the engine suck its 1.6l from the tube, the air travel much faster in the stock intake,
most cold air uses metal piping witch have an inside diameter a little bigger than factory so the same amount of air (1.6liter) travel much slower when passing thru MAF. ( try blowing in straw vs blowing in a scott towel pipe, the air goes faster in the straw)
so here is what i did to overcome the MAF from sending that there is low airflow when the engine actually gets the same amount of air (or more) into the engine :
in the piping where the MAF is located, i inserted a 2" rubber pipe for plumbing, used for coupling 2 pipes together that i bought in home depot (7$)
the fit was really tight... where the MAF hole is, i cut a new hole in the rubber tube to inserted back in place the MAF,
result : at the MAF location in the intake tube the diameter is slightly smaller so at that place the airflow is augmented, thus the MAF read correct airflow, sending correct data to ecu witch shoot right amount of fuel.
no hesitation when at partial throttle, or cruising highway. the power curve is more steady too. not like before : "underpowered then bam!, OH there is my 105 HP!"
if you need more explanation just ask.
Thanks
Samuel
Xplicid Protege said:I have an weapon R intake short ram and im getting 9hp with no check eng. light.
