Sorry Guys, just want to wait until I got the front sway bar installed and drove the car for few days first before I post again.
After driving the car on Angeles Crest Hwy. from Pasadena to Palmdale few times with the new bars. All I can say is this $400 is well worth it, and I want a turbo.
Quality of the Bars:
Very good finish quality. Other than the thickness, it is the same as our stock bars.
Riding Quality:
On normal surface, similar to pickup truck.
On uneven surface, you will feel every bump.
Handling:
In & out of the corner is better and faster than the 05 WRX I drove, a lot less body rolling.
Steering return to center a bit faster.
Installation:
Very easy to do if you have the tools, most bolts are just 14mm, 17mm & 19 mm.
Front bar look scary to do it yourself because you need to unbolt the front sub-frame, but it is not too bad.
If you have access of a ramp, you should able to finish the installation in around 2 hours.
Here are some pictures of the bars installed. You can’t really see the bars from regular angles.
http://picasaweb.google.com/king57721/COBBSwayBars?authkey=Sm0I6e1dl2Y#
