- 2007 MS3
I am able to get a fair amount of oversteer on my stock 08 MS3 without too much over exuberance in tighter turns..not a slow roation but fairly abrupt rear end "let go's". I would be reluctant to stiffen up the rear sway on my car without some major pansuspension modifications. The MS3, to me at least ,seems to handle w/o the noticeable oversteer or "push" that is associated with most FWD's....what some feel is oversteer can be significantly remedied by tire choice. With a set of Kumho V700's, the only end that lets loose for me is the rear (with the DSC off obviously).
Some of my past FWDers have benefited from a stiffer RSB to counteract understeer but I think Mazda has set things up pretty decently straight from the Factory.
While a stiff set-up is needed for the track and fun on the street if road conditions are "track-like", going around a fast street corner with a frost heave or sunken depression can ruin your day in a hurry. A stock suspension set-up is easier to save than a non compliant comp. configuration.
This is why I keep harping on the point that if you keep the factory front bar and put in the Cobb rear bar, go with the milder of the two settings. I agree that the factory did a pretty good job, so you don't want to go overboard with the changes.
With the Cobb bar on the milder setting, when I drive through the twisties, the car tracks flatter during the right to left and left to right transitions. I have no idea what it would do under race conditions, but for just having fun on a winding back road, the changes I'm experiencing make it a blast. I have much more confidence in the car now. On a race track or an autocross course where you are deliberately trying to make the back end come loose in a controlled manner to get around a tight turn faster, I have no idea what effect the bar would have, but I don't do that stuff: I just like to go fast down windy roads, and this bar makes that a lot more fun.
