So I thought I'd throw up a little comparo between the COBB and Hotchkis rear sway bars now that I've had both. Keep in mind too that I'm rocking the stock FSB and springs.
Both rear sway bars replace the stock RSB and are 2-way adjustable. COBB claims stiffness of 50% in the "soft" setting and 90% in the "stiff" setting. Hotchkis' numbers are 90% and 140%, respectively.
Here's a pic of the two bars together. They are just about the same thickness (~32 mm), but if you notice, the endlink mounting points are much thicker on the Hotchkis. The Hotchkis bar is, I'd say, about 50% heavier (in hindsight, I wish I took the minute to weigh both on a scale), than the COBB bar, despite being the same thickness. Tapping gently on both, I could tell the Hotchkis had beefier walls, hence the extra heft:
Here's a better shot of the tips to show the difference:
And here are the two mounted. Notice the COBB bar has two shoulder flanges that secure the brackets and prevent the bar from shifting left and right. The Hotchkis does not have these, so instead it employs collars. Aside from that, the install is identical.
I only had the COBB bar on for 600 miles and never really had the chance to push the car above 7/10ths. Same with the Hotchkis, still haven't really beat on it yet. Nevertheless, I can definitely feel a difference between the two. Despite the extra stiffness, the car with the Hotchkis bar still feels very composed and predictable on the streets.
Oh, and the red matches the car.
