COBB Downpipe released!
Champloo
2007 Mazdaspeed3 Black Mica
COBB released their catted downpipe/testpipe piece. It looks awsome! (yippy)
Here are some of the highlights:
Increased horsepower and torque
CAD designed cast turbo outlet for maximum flow
Minimal bends for less restriction
304 stainless steel throughout for corrosion resistance
Custom spun metal substrate high flow cat
Internally lined stainless steel flex section
Three O2 bungs for factory sensors plus aftermarket
Cross-welded and braced hanger section for added strength
Polished tubing and cat for attractive finish
Factory location of flex section eliminates stresses
Stock donut gasket for optimal sealing and long life
Compatible with all cat back exhaust that mate to factory downpipe
http://www.cobbtuning.com/products/Default.asp?id=4299
Group Buy anyone???
Not any more so than the CPE catted dp/rp combo. I agree it is on the high side but not unreasonable for people who want the power increase but to retain a cat. I was hoping the price would be better but maybe a group buy will cut it down some.
WANT...Although this does make my Corksport Test Pipe a little obsolete...
what did you expect. its just shy off their exhaust price. im sure the quality is up to their standard but for alittle bit more you can get a turboback.
no all the way obsolete(spin)
cp-e or the cobb...how the hell am i going to decide...
if only there was a way to make a 50/50 decision easier. some arbitrary way to decide one over the other without having to go through the pro's n con's of each...
Flip a coin...thats about as arbitrary as you can get..
if you kids venture over to the .org forums, you might be able to score a CP-E DP for almost $110 less than the Cobb DP...
