i appreciate the response from a cobb person - but i've done a great deal of research now as i'm only new to this forum not to the car or it's aftermarket - and from what i understand there are some misconceptions in this thread about cpe's products - from what i now understand the fuel cut, cold cut, and other flashes besides full control flash were all designed for someone who doesn't want to run the sb and just wants to let the ecu adapt (super ride mode) - if you know how to use the sb and tune with it, all you need is it and the full control flash - none of the other flashes are necessary - i am most likely going to go with the sb as i am already a little familiar with it's software and how the feedback loop system works - even tho i initially said i only wanted to do a few tunes, i see myself always wanting to try different things and keep doing different tunes all the time as a friend of mine w/ the sb is always doing - as he learns, i will learn and i will make similar adjustments and never have to worry about a limited number of flashes i can do - the only drawback i can see is the potential of the ecu relearning things, but after more research i find this is something i hear from people who own the cobb product and don't really want to give the cpe one a chance, the people i've talked to w/ the sb say the only issue may be timing adjustments as far as re-learning, but there is a point where the ecu can't adapt any more and the sb takes over - it's a just a matter of tuning to that point -
Friend, I'm sorry but you are the one with the misconceptions.
Full Control Flash = Full Throttle Plate Open
Cold Cut Fix = IAT Fix to solve the fuel cut associated with the IAT issue when temps drop below 40deg (where most people report getting it).
Larger MAF = Allows use of a 3in MAF
These flashes are things the SB can't do alone friend. You can't TUNE OUT the Cold Cut issue. It is impossible with the SB, you have to have the flash to fix this issue.
I'm not sure where you are getting your information, but you are dead wrong if you think you can tune out the Cold Cut using a SB. The Cold Cut Flash was created by CPE because those people with the SB had cut all winter long and CPE worked hard to find a fix, IE the Cold Cut Flash. They did NOT design it for those without a SB (however I guess it could work as well). If you could tune it out CPE would have just told them how man. If you live anywhere that the temp drops below 40degs, you need this fix or you WILL get cut during the cold months. That is a guarantee. Now of course you can get the SB now, then later get the Cold Cut Flash to fix the cut you get in the winter. That will spread out the expense.
I really could care less with which choice you make, I simply don't like seeing fellow Mazda members buying something thinking it does one thing then finding out it does not. So my motivation here is to see you get something that meets your needs.
Keep this in mind - People will always stick with what they know and defend their purchases. Your friend is running the SB and praises it I'm sure. Had he been running the AP he would do the same. You as the buyer need to utilize some common sense and read between the lines. I can tell you have not done any research on the SB as if you actually did you would know what the Cold Cut Fix is and know that you can't tune it out with the SB, you have to have the flash. So do some reading. Try to stay away from the biased people and read between the lines as best you can. Don't take your friends word for gospel as he purchased the SB and is about as biased as can be I'm sure. The SB is not a bad product man. However, in my opinion, it is no longer the best choice now that the AP has the ATR out and you can custom tune using it. Out of the box the AP gives you way more than the SB ever will. The ONLY reason to use the SB at this point is if you want to run a 5v source (meth for instance) and let the SB control it.
DashHawk - Your DH will NOT see your Boost with the SB as the SB lies to your ECU. Thus your SB will see what your ECU sees which is NOT the actual boost. You will 100% need a Boost Gauge. The DH can monitor the rest.
Re-Tuning - Dude the SB is a Piggy Back. The problem with the ECU learning around your tune is that you really don't know unless you keep a constant vigil on it. Notice your boost spiking - Time to log. Car feels sluggish - Time to log. Didn't pull as hard as yesterday - Time to log. Sure it might level out a bit, but when temps change going from summer to winter, you start all over. That is the price you pay for a Piggy Back solution.
Seriously dude, ether listen or stop asking questions. People here are not trying to BS you as much as you would like to believe it. If you want to go with the SB, do so. Just know what you are getting when you do because of right now you seriously don't.
