Cobb AP Discussion Thread
Just order my AP from PG cant wait for it!!!! So what sparkplugs should i get? sorry if its on the thread already....o btw which map should i run the - Stage1+MSCAI 93 v102 i have a Mscai,ets 3.25 tmic,2.5 inch custom cbe, turbo xs hybrid bov... or should i run the - Stage1+FUCAI 92 v102 + TMIC any dif between the cai's? anyways let me know
You answered your own question. It's all been discussed in this thread and in the sub forum. Take a few minutes to search.
forgive me if this has been covered. but, for the maps that have a turbo inlet hose, does it matter which one you have?
physically, all the inlet pipes are the same right? granted you have one that could potentially bolt up to the stock turbo and air box.
It's nondescript, basically any upgraded TIP falls into the maps they make with the 'TIH' designation.
right so with an ap, i would wanna use a map that had: TIHCPN+TMIC (93 octane)
only map i see like that is: TIHSF+TMIC(93 octane)
so i have to us a cobb SF with that map, right?
tryin to get what works with the ap.
Yep, I would email Travis or Christian and find out if the Cobb maps translate well with the CP-e ones.
You could also run a Stage 2 93 map without any added enhancements if you choose.
Ok guys. I have been searching for a long time and cannot find the information. For a MS3, is the only place to find OTC maps on Cobbs website? Is there somewhere else that is reliable??
So I'm told that you can run the cobb ms3 1.05 maps on a ms6. Is this true and if so should I stick with my stage 2 sf 1.02 map or try the ms3 stage 2 sf 1.05 map?
The AP won't let you, the vehicle info won't show those maps on the MS6 if you try. Where'd you hear that?
i used to have a ton of ms3 maps but i'm lazy and dont' feel like uploading them and just don't have the time now.
ok well put stage 1 sf 93octan and holys*** what a difference i was spiking 20psi and dropping down to 18psi is that normal? my afr was between 14.3-14.9 at idle and between 10.8-11.5 at wot but the car felt unbelievable after 6k lol haha anyways i did get a cel it was to lean at idle bank1...i was reading up on it and i cleard the code and going to see if it comes back..if so prob a boostleak? idk i need to get sparkplugs too..anyways i love it...o and how do i download my data logs?
I need to download the Stage 2+ TIHSF, I just got the Cobb SRI for Christmas and I'm going to switch to a more fitting map. I'm trying to remember, was this the map we had issues with knock a while back?
Yes, I spiked 5.4 KR on that map. I don't recommend using it.
