96superneon
- 2001 Mazda Protege MP3
So i've been having trouble with my clutch engaging, having to pump it to get into gear. Read that it is either the slave or master cylinder causing it, or possibly air in the line. I took off the slave cylinder to reverse bleed it and thats when i noticed that the plunger isnt plunging. I took off the slave cyl and took it apart and cleaned it out. When i put the cylinder back together the plunger still didnt plunge. The spring isnt broken, but could it just be worn out? So now its all back together and put back on my car and now i have no pressure at all no matter how many times i pump the clutch.
