***Clutch pedal NOT holding pressure - help asap***
Even if I order it tomorrow, the soonest it'll arrive will be by next tuesday.
I'm just going on and on...
Here's the real question, what is the name or part number of that black hose?
Clutch Hose?(that's what mazda of oakland called it)
and where can i buy it or something that will fulfill my need.
A simple google search would have led you to this
http://www.horsepowerfreaks.com/partdetails/Techna_Fit/Clutch/Clutch_Lines/Red_Coating/5898 And for $25 not too shabby either. Have fun, now get to it! (outie)
PS overnight will cast around $55 total. Good Luck. :)
Did you check to see if its the clutch master cyl.? All u gota do is look under the dash with a flash light and pump the clutch and see if any fluid comes through the seal if its the clutch master cyl its a pita especially if ur a big guy like me and don't have a bleeder tool. How low on break fluid was ur car after it started doing this? If its half empty it can still let air in even if u bleed it there can still be a lot of air in it. When u pump it it will build up preassure around the air but when u keep it in that preasure will release. It is confusing but I learned the hard way also pump the clutch and pull the slave cylinder off if there is fluid where the rubber ends it could be that. The easiest way to see which line is bad is pull one off at a time clean it real good plug one end spray cleanser on it in small sections and blow into the unplugged endbif u see bubbles come up where the cleanser is you found your leak. And why so much for a rubber hose that short? I believe your talking about the one that goes from the master cyl. To the clutch master cyl. If that's the one then take it into any parts stor and have them cut a section off the same diameter be cheaper faster and probly just as good.sorry for the long post but figured I would include everything
If it is still full after pumping it and everything you could simply have trapped air in the line get a leeder tool and bleed it makes sure the resevoir doesn't get below 3/4 full bleed it untill there is no more air should fix it
