Clutch issues
FLSilverP5
2002 Protege 5
My friend has the Mazda 6 6 cylinder manual, after only 30 k miles he needed to replace his clutch. is this a common problem for the 6?
now he also has clutch chatter when starting off from 1st gear, any ideas?
honestly, some people are a little more rough on the clutch than others. it also depends on what kind of driving you do. I know I'll probably have to replace my clutch early beacuse sadly, I do a lot of uphill stop and go traffic (hence the reason I'm trying to move).
SeMentor said:
how do you know when the clutch is about to go out?
You will feel it slip when you try to engage it. I had a bad clutch on my 626 and I was just about to pull into traffic. You will definately notice, because you will have to ride the clutch to get it to engage.
