Volley2six
- MP3
Can I go to a dealer to have a TSB fixed even though I don't have a warranty since I bought the car used? Sorry for the threadjack but if this becomes a TSB or something I wanted to know if I could take advantage of it.
ahb11m said:just out of interest do you know if this was an isolated incident to northern america? i have a similar problem with a 99 protege BJ and am now confused!!
any help would be appreciated!!!
i have an AUS spec (close enough to JDM.... ok not really) but the starnge thing is it sounds like its only coming from one side.... funnily enuff the right hand (drivers) side also the muffler side.... i had the bushings replaced recently and it did disappear for a while, when it returned i took it back to a suspension shop, and they had a look at it... they measured the shocks etc and found them to all be measuring with low pressure, but also mentioned that they had measured the same/similar readings in the ford laser (cheap ford 323 rip off) and the newer bj 323s.....
it gives me the s****, but i don't think mine is quite as bad as you guys... i generally don't have any cold problems.... been only having lows atm of about 11C and highs of 27.... summer is about 35 highs...
does this sound similar to anyone elses problems???
