Canecreekfreak said:Yeah, I put the stock intake back in for the visit to the dealer, and there's no more clicking.
The engine still stumbles at idle, though. It wants to stall but doesn't. Think that's due to the shutter valve? Will a weak battery cause this to happen?
Moeed said:Currently my car makes this continous ticking noise, and when I push down the clutch pedal, it goes away. If your car has the same symptoms then its probably it. Its doesnt mean that your car is going to break, but if you do some tranny work down the road, replace that pilot bearing.
benzete said:my engine was doing that clicking noise for like 3 days straight, and then it went away, mainly because the engine blew. it would only do it at certain rpms. i would take it in asap and drive it very gently until it gets fixed
SlowPro98 said:What's Up Lee? if your engine still stumbles, check the EGR valve cleaning thread in the How-to section.
did you reset your ECU when you put the stock intake back in?
I'm guessing your tick is the same tick I have, with is the purge valve, cause I have my on my stb, I'm going to try and fab a bracket similar to the one that John (Ronin) has in his.
