Class is in session: NC_MP3 take a seat!! (LONG!!)
Okay, the following will be long, but I promise you, it will be educational!! For those that dont know what this is, it is in response to NC_MP3s ignorant commentary from 3 separate threads that can all be referenced here:
http://www.protegemp3.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=4&t=000079 http://www.protegemp3.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=4&t=000098 http://www.protegemp3.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=3&t=000300
Originally posted by NC_MP3:
<STRONG>I seem to have shut him up hehe.</STRONG>
Sorry..too good to be true!!
<STRONG>I beat a stock Z28 by about a car length. How much HP do they have? Like 300 + right? Don't say I am BSing when you have no clue what you are talking about. I am new with Mazda but Honda is what I grew up on. </STRONG>
Great, Im happy for you, really!! BTW, they have 320 at the crank and Im not the one comparing a FWD to a RWD. You cant compare drivetrain losses between different classes of drivetrains. Youre the type of guy who probably thinks that 250 @ the wheels on an AWD vs. FWD/RWD is the same. Do you know why it isnt cuz Id love to hear your thoughts?? Please tell all of us and if not, Id be more than happy to explain why.
Hmmm..16 to 20 huh?? 4 years old is hardly grown up, looks like you still got some learning to do. Heres the difference between me and you, you have what you call, "grown up" on hondas and admittedly and obviously have limited knowledge of others, while I on the otherhand, have knowledge of many manufacturers, both N/A and turbo applications. Does that make me specialno!! Everyones gotta start somewhere and I just happened to take the diverse route, while you tried to focus your knowledge.although it looks like you need to focus a little harder.
I only got my knowledge through people far more knowledgeable than I and that have been doing it a lot longer than I. Did I get mad and throw a fit..no, I pulled out the pen and paper and started taking notes. You should too!!
<STRONG>Oh, and if you didn't know the LS engine is far better than the GSR. Only thing GSR has going is the Vtec head. Cause anything you do to an LS and a GSR, the LS will always yield more power.</STRONG>
So why is it that all the drag integras utilize a GSR motor instead of LS motors if that was so true?? Look at all the top runners and you might start to realize a trend!! Once again, its like yelling at the def!!
Anyway, you actually make a valid point here, but not altogether true. The LS engine has characteristics that are better than the GSR for certain apps and certain goals, but not always. In this situation, you have made a good point by pointing out the compression on the LS is better for turbo apps, but do you also know why the LS responds better than the GSR to boost other than the lower compression?? Please, humor me and take a shot at that question.
For now, I will admit this, the LS gets more gains from boost than a GSR, but not better peak #s. In other words (ballpark #s), for the same setup, lets say a GSR gets 90 hp from boost to increase to 260 hp, while the LS gains 110 hp to take it to 252 hp. In the end, the LS gained more, but the GSR is still putting out more peak hp, which is what my original point was. I never said the LS didnt respond well to boost.
<STRONG>Why do you think people buy LS's and then put a Vtec head on it? </STRONG>
I can give you 3 good reasons why people do it:
1) Its cheaper overall than a GSR when you add up the final cost.
2) LS engines are far more readily available than GSRs, although neither is really that hard to find nowadays.
3) They smartened up and realized that VTEC=power. Why do you think the STIs make more power than the USDM spec WRXs?? Its called variable valve timing!!
<STRONG>We should be able to run 6 psi on a stock engine. </STRONG>
For once, we actually agree on something!!
Originally posted by tritonheat1:
<STRONG>Hey Apexistud sorry i gotta say that Nc is right cause my brother in-law's brother is running 7psi at 263whp Plymouth laser Rs-t dynoed but i don't have the sheet if that's what your asking for. Trust me you could make a Ls Integ run 0ver 250whp with a T3/T4 or drag kit stage 3. think about it as Nc was saying he was stuck on honda's, ive seen Honda's with stage one turbo's headers and turbo controller running 230++whp. A dude that i know lives here in my town owns a LS integ and dropped a 1.8l GS-R motor with an Aem cold air Intake and have kept up with Type R's do to the fact the Ls weighs 2400-2500++lbs and might of added a little few extra weight dropping the GS-R motor. But he has Beaten Si with stage one turbo's alot and quite abit a couple car lenghs and people think he is running NOs or clutch set. and the bad thing is they don't know he has a Ls integ with a GS-R motor with an Intake. </STRONG>
Im sorry man, but what the hell does a plymouth laser rs-t and what it puts out have anything to do with a turbo LS or GSR?? Lets compare apples to apples, not apples to oranges. Dont compare cross manufacturer motors that arent even close to the same. For christ sakes, one isnt even turbod from the factory and the other is. Why do you think those guys ditched the LS motor for the GSR?? .
All you did by posting what you did was confirm what I was saying, so thank you!! Another FYI, when you swap motors, you no longer call it an LS just cuz the body is the same, it is essentially a GSR cuz that is what it is powered by. The proper term is "hybrid" man!!
Okay, now lets get to what the point of all this is, the actual facts and real dyno sheets.
<STRONG>I got my ~265 whp from 5 different people. 3 of those post regularly on message boards, as do I, 1 is an AIM buddy, and 1 is a RL friend in another NC city that has an LS. All 5 of those people have that same kit, and all 5 have told me they dyno'd the car when the kit was put on and they got ~265 whp. One guy had like 250, one had 270 something, but all were close to 265. All of them said they were running anywhere from 6-7 psi. Again, one guy was running 6, one 7, and so on. That is where I got my numbers from. Now don't ya think its funny that all 5 of them reported about the same HP? Why would all those people lie? </STRONG>
Well, which is it..250 or 270?? 6 psi or 7 psi?? In the end, none of your results give concrete figures to judge off of. All you have is a, sketchy at best, article from overboost with no dyno graph available to say at what octane, what exact boost, what kind of timing, what other additional mods, whether its SAE corrected or raw #s, what kind of dyno, or environmental conditions (not so important)??
I give you here 2 different LSs that would show differently than you suggested. Notice, the #s produced with your same drag III at 10 psi fully tuned on 93 octane w/no cats!! That is a big difference than your #s man!!
The second one is another turbo LS at 9 psi and only running 244 whp and 210 lbs/tq:
Cmon man, how much do you need?? Do you need more?? Okay, here is the link to the second one:
http://forums.clubsi.com/ubb/Forum12/HTML/007615.html
Look at what the second guy says about his friends built LS and I quote for the rest of you that choose not to go to the link, "My buddy had a built LS with dropped exhaust 12-14 psi put down 266whp and 222 ft-lb! He went 12.60 in it and a guy on this board bought it imprauv!?"
Does that make me right and you wrongno!! But it does give me basis and reason to question your #s. Do I think youre #s are wrongno!! I just think you are not getting the full information behind those #s produced.
You have to remember, I live in CA where #s are exaggerated left and right. Its the land of the best, but also the land of rice!! There is a lot of BS floating around. We can only run CA regulated 91 octane pump gas while most of the rest of the country, gets 93 to 94 octane on a regular basis. Understand my point of view comes from this and those #s seem very inflated from this point of view.
When you get to that next level, you too will start to ask the same questions I do when I hear exaggerated or inflated #s. How do you think people and technology advance?? By just absorbing everything they here or finding out more details about how things work and what it is exactly that produce those #s.
What I will apologize for is that the board has to hear your mouth on a continual basis!! Enry and the rest of you, I commend your patience. This guy and his attitude wouldnt last a day over at I-club!!
Originally posted by SanFranMP3:
<STRONG>The bottom line is that power is expensive, and doubling the hp from an engine with a simple bolt on kit and 6psi is absurd. </STRONG>
Couldnt have said it any better than that my friend!! You seem to have a good grasp on reality and real world #s. Dont lose that as its a valuable and too rare of a quality in the import world. Its no wonder Domestic guys laugh at imports and continually make fun of our 4 bangers when people start spreading unreal stories and hearsay #s.
<STRONG>If I were wrong, I would admit it and move on. </STRONG>
Thank God, does this mean you will be moving on now??
[ 11-14-2001: Message edited by: subywan-kenobi ]
Is there a moderator that can shut this guy up? Since he has come to this board only thing he has done is b**** about how he is right. He took a simple thread about turbos, and turned it into a ******* war about Honda engines. THIS IS NOT AN INTEGRA BOARD! I made the ORIGINAL post to show the fact that my Integra gained ~140 HP with a turbo kit, which was the TOPIC of the damn post, practicality of a turbo. I in no way started a fight, I in no way said, this is how it is cause I said so, I in no way pissed anyone off.
Then you come along and being the dick you are start flaming me saying what I am saying is BS. Who gives a **** on here what my Integra can do? Point of the thread was, turbos can add ALOT of HP, so when a kit is made for our cars it will be practical cause it will add alot of HP. Did I say a turbo will add this much to a MP3? Did I in any way feed a bunch of BS to these people about turbos? Can a turbo kit add 140? YES That is all the thread was about.
So my point is, get the **** off this board if you don't have anything productive to say about an MP3.
Case closed, end of discussion, for me anyway.
[ 11-14-2001: Message edited by: NC_MP3 ]
We need more guys like these two in here.
It is like a soap opera after I get off of work and read all of this.
It is like...I can't wait to see whats gonna happen next?"
It just pulls you in. :)
[ 11-14-2001: Message edited by: MP3-Owner ]
BTW...I know NOTHING about cars(not much anyway) so don't go asking me 20 questions. K?Thx! :D
I am simply responding to what I am reading. :cool:
Its cool MP3-owner!! I hope that is what you are getting out of this......some good laughs. I can't help but laugh at how some people respond to people who don't think as they do.
Anyway, its not about egos, its about sharing our experiences for the advancement of all our knowledge, not just what my car puts down to the wheels and thats the way it is.
Call it egos if you want and that may be how some see it, but for those who are true enthusiasts, they will not bash either of us when the topic is on cars. When they go to the level he takes it though, thats a whole different story, completely OT.
BTW, I know you all are enjoying this, but I you won't see much more out of me in this regard. It shows poor taste on both parts, but its something I've acknowledged, so I won't be engaging in anything but educated arguments from now on.
Sweet car BTW! I love that carbon fiber hood. I hope to get one for my MP3 one of these days after I get all the go fast parts done. :D
"It's all about the cars!", MP3-Owner
Oh! and your name...Hahahaha, that is nice and creative Big Thumbs Up! :D
I might just change mine to...MP3Oh! Whatcha think? eh?
Ya'll chill out.. okay.. I'm the moderator.. and unfortunately I got here late...
Please, if you have some sort of discrepancies, why can't you discuss it in an adult manner.. all this dissing and "he said she said" insulting needs to quit.
Class dismissed..
