No photos today but I did some more work last night.
I ****** up when cutting the holes for all the wires. Part of my rack cracked because it was too thin. Oh well. I knew I was bound to **** up something up along the way. Maybe I'll fix it later. I need to get some sort of gaskets to clean up the holes which I made with a 1" spade drill bit. I probably should have used somethign else but that was all I had.
I blame it on my overall design. I should have incorporated more space for the RCA cables (they stick out pretty far from the amp). If I designed in more space I could have folded all the wires under my silver mounting board and fed them through a hidden hole. I could have done that if it weren't for the damn RCA cables...and I thought of L-adapters too but that still wouldn't work. ahh, whatever...you won't even see the holes when viewing the rack from the back of the car.
I mounted the amps and processors. The amps are bolted down with security screws. I was gonna use them on the subs but the heads were too small. I mounted a 1f stinger capacitor under the amps (there is dead space in the tire well that I am making good use of). Lets not debate caps...I had it from a previous install and it has a nice fused distribution block on the top so...whatever I'm using it.
I ran KnuKonceptz 4-wire RCAs between the processor and crossover, and crossover and each amp. I ran 8ga power wire from the cap to each of the amps. I linked up all the remote turn on wires by just sinking a screw into the back of the rack and using it as a binding post. It's ghetto and I'll prolly pick up something at Radioshack later to clean it up. I ran all the speaker wire to a 15-pin molex connector (only needed 12 pins, so I used one for the remote turn on also). At that point it was about 11:45 so I called it quits.
This weekend I have a few more things to do...
- wire and install the subs.
- secure all the wiring so it doesn't vibrate
- connect all the speaker wires in the car to the female molex connector
- install the rack! woohoo!
- secure the rack (I have some L-brackets that should do the trick as long as I don't put a screw through the gas tank)
- carpet the trim pieces and install them
- design, cut, and finish a cover piece
- and of course...adjust all the settings and tune everything!
