I would like to be able to check the amount of boost I am getting, just to be sure that everything is working right in terms of the turbo and the BPV. I don't really feel like I need to constantly see the boost levels(In other words, I don't think I need a permanent hard wired boost gauge). Is there some cheap way to check that, or would it be best just to get a dashhawk or something? I know there are units that you can get to allow you to hook up your laptop to your ECU to see some readings, but I think the software to go along with those cables gets expensive too, and at that point it would probably be just as cost affective to get a Dashhawk.
I'm thinking about going the dashhawk route because if nothing else I can use it for a boost gauge, and for reading error codes that may pop up on this or our other vehicles.
Does that make sense? Any other suggestions? Anybody tried the laptop route?
Thanks.
Thanks.
