boostdprotegelx said:hmm..is there a way to keep that kinda heat down? and when you are talking about that heat, how do you see that heat?
No.. that's my point... this isn't simple.. this is a HUGE thing... and it takes a lot of design work and planning and reinforcing to do it... again... you need to set and use goals for the car that fit what it is going to be used for... the only way to combat the heat is with very expensive components that can survive it... and we don't have some of those components (like the necessary valve guides) that I know of at this point... not to mention trying to effectively cool all that.. it's more than just a big radiator.. the water passages and flow rates and fluids and oil paths all have to be right.. and I don't know that they are.
The aero alone will be out of reach of anything you are looking to do... realize that takes genuine wind tunnel time to rework the profile of the car to get enough aero so you don't flip the front end.
