TurfBurn said:Dana... Fourth gear is a .972 ratio... based on that and assuming a redline of 7000 rpm's I get that he can do roughly 128.5 mph.
I'm assuming a redline of 6500 since that's what redline is on our cars.
Can you show your math?
Based on this calculator I got 112mph @ 6500rpm and 121 @ 7000rpm (ie, way past redline).
I got my gear ratios from this site.
However, your numbers seem to line up if you use what they list as the MSP trans...which is apparently different than the trans in the other Proteges.
Not sure if what's listed as the MSP ratios are correct (these are the same numbers that Edwin has on his FAQ), but I can tell you with 99% certainty that those are not my gear ratios, in any trans I've ever had on this car.
If I had those ratios, I would not have to bring it past redline to get to 60mph (which I know I do), and I know for a fact that I can't hit 88mph at redline in third. I also know that I shift out of fourth and into 5th at around 110mph, because I'm just about to shift into 5th as I finish the quarter mile (@107mph).
Five Speed Manual Transmissions
Trans Model First Second Third Fourth Fifth 2003 MAZDASPEED Protog 3.307 1.842 1.310 0.970 0.755 2003 MAZDA6 i 3.307 1.842 1.233 0.914 0.733 2003 MAZDA6 s 3.153 1.842 1.258 0.947 0.733 5MT 3.136 1.888 1.330 1.000 0.814 M5OD-R1 3.720 2.200 1.500 1.000 0.790 M5OD-R1HD 3.400 2.050 1.310 1.000 0.790 G5M-R 3.666 2.059 1.310 1.030 0.837 G15M-R 3.666 2.059 1.310 1.030 0.837
