To my knowledge, there is only one street legal LED into a Halogen housing bulb on the market anywhere in the world, the Osram Nightbreaker LED. That's literally it. Only problem is, it only comes in size H4, and your high beams are 9005, so it's not even close.
But don't despair, I have a fantastic cheap and easy upgrade! Instead of using a 9005 bulb, get a Philips Standard 9011. You'll have to trim the mounting tabs just a little bit, but that's easily accomplished in seconds with a pair of wire flush cutters.
The difference in lighting output is nothing less than astonishing. And did I tell you they're cheap? Because they're cheap!
Seriously: go that route.
