Change cabin air filter 2016 CX-9?
ioiwin
2016 mazda cx-9
Hi,
Wondering if anyone has changed or knows how to change the cabin air filter in 2016 cx-9?
Or link online? Thanks y'all,
Hi,
you can go to part source buy them $26.99 (dealer $39.99 plus taxes). It should take you less then 2 minutes to change it. You can go on youtube search for it. Mazda dealer is ripppppp offfffff.
According to others, it's behind the glove box (as usual).
Buying new ones is pointless unless you're really in a dusty area (or if you park your car under a Birch tree dropping seeds into the intake and then find your AC condensate is clogged and splashing water on your passenger's feet.)
Since the charcoal layer is so pathetically thin, I just pull it at each oil change and blast it off with compressed air. Failing that, wacking it on the ground works too. LOL
