I had my check engine light come on 2 days ago. just in the middle on my way to football practice. And it was on all day. But the next morning it didnt come on when i started the car. But then later that day in a middle of a drive it came on again.
So i went to autozone tonight and checked it out. and it is the PO171 which is:
Definition
Fuel trim bank one condition
Explanation
The powertrain control module uses the oxygen sensor to calculate the air/fuel ratio of the engine. The computer has recognized a rich or lean condition on one engine back only.
Probable causes
1. If bank one and two codes set together suspect fuel pressure or MAF
2. O2 senor defective
3. Ignition misfire- repair
4. Fuel injector problem
This is what i thought the problem might be about because i recieved the car july 5th... and i was not aware that the car needs premium fuel so ive have drivin the car about 700 miles since all on regular gas. this afternoon i filled it up with 93. so could it be on just because of the poor gas? or could it be something bigger?
btw. the car is all stock except for a injen CAI. and it has 81k miles
Definition
Explanation
Probable causes
