P Pheonix Member : '03 Emerald Mica Protege May 30, 2005 #1 i'm not sure if the amp is mounted too low or not, could this cause problems if anyone has any pics of their amps mounted, that'd be great. Attachments caputer1.webp 26.7 KB · Views: 176 carputer2.webp 56.5 KB · Views: 170 carputer3.webp 60.8 KB · Views: 187
P Pheonix Member : '03 Emerald Mica Protege May 30, 2005 #2 ok, maybe a little detail will help it's a crappy 500 watt Rampage 4-ch amp. seems to run well, ~4 amps current near full level running only 2 channels i'm just wondering if the power and outputs touching the bottom carpeting will be a problem. nick
T Tangent Member : 2002 Protege5 May 30, 2005 #3 well...i would have to say that it is a very very bad idea, and that the contacts should be touching nothing but the intended wire.
