Car squeaks
Good_Old_Maui
2003 mazda protege5
I dont know if anyone else is having this problem but my protege5 squeaks on acceleration while cold but it DOSENT squeak on a cold start the squeaking stops after engine has warmed up also the car squeaks when i turn the defrosters on. Both my belts look new and i cant figure the problem my A.C also only kicks in on 1 and 4 speed not sure if it is the same problem
Is it a belt squeak? If so then replace the belt or try to tension it a bit more. Maybe put a bit of rubber grease on the inside of the belt (only a tiny amount thought)
While it's running and squeaking try spraying a bit of water at the belt and see if it goes away for a few rotations. If it stops and comes back if get a new belt
