mazdarichie
- 2003.5 Mazdaspeed Protege
Ok I changed the lines so far just from the intake manifold down to the T and to the bypass valve and down to the WGA. Same problem. If I clamp off the vacuum line below the T just to the WGA it will pick up to about 20 inches of vacuum. If I take the clamp off it drops back to 14 inches. If I clamp off the bypass valve only there is no change at all.
