I've been trouble shooting this thing for 5 days, so here is my scenario.
One day on my way to work, half way there, the car began to bog, hesitate and back fire when i began to enter boost. Since then, ive noticed the car works mostly alright if its JUST started, not warmed up, but after it begins to get hot, i cannot enter boost. I CAN go all thorugh the rpm band if i stay out of boost and accellerate slowly, but as soon as i hit even 2-3 psi, i begin the bogging and the hesitation and backfiring and complete loss of power.
I've tested for ecu issue, maf sensor, coils plugs and wires, all boost leaks, scanned all my cel's (high circuit maf - fuel cut frm trying to get the car to act normal) and i am now at wits end. I just put the timing belt back on thinking it may have skipped a tooth. I found the tensioner was loose, but the timing was still good.
I didnt get a chance to test drive it after i put the belt back together, but i am also getting tired of throwing parts at it. It just happened all of the sudden, i had done nothing to her prior to this for about a week or so.
motor related mods..
built cunningham rods, weisco pistons
1.8l coils and wires
tubular manifold
14b
2.5'' to 3'' dual tb exhaust
removed vtcs and vics
fmic, hard pipes and rfl bov
removed egr and evap
removed a/c
p5 radiator
mbc 10 psi
and some other junk im sure im forgetting..
Anyone have any suggestions?
tubular manifold
14b
removed a/c
p5 radiator
mbc 10 psi
