If you guys want to know an interesting bit of trivia, it's that cars pollute more in the first mile than the next fifty (on one drive, that is). For ULEV's (like the p5), it's more (in some cases) in the first than in the next 500. I'm not sure what the p5 is at, probably 1/100.
A simple solution to this is being used by Saab, although I'm not sure if they're using it in the U.S. yet. A bag or cylinder located under the trunkspace traps the first "mile" of emissions, and can even be pressurized (the emissions can be "pushed" into a smaller space). Once the cat is hot, the computer releases the exhaust gases pre-cat back into the exhaust system, allowing them to be processed like the rest of the gases through the catalytic converter. It reduces emissions to next to nothing. Similar designs are being considered in Cali (for all you west coasters), but may be nixed by the proliferation of hybrids, which can heat up cats electrically shortly after starting, precluding the need for a storage chamber. Either way, a solution is out there.
just thought that was a cool fact.
