Bypass valve flex hose upgrade
Mid_Life_Crisis
Contributor
2007 MS3
I saw a thread about this a while back (I think I even asked about where to get it) but now I can`t find the thread. I believe the flexible hose used was purchased through Summit, but I`ll be damned if I can find it on their site. Does anybody know where to get this and hopefully have the part number?
is this what we can use to run the HKS in recirc? As in does it stretch and bend without kinking?
I just bought a silicone hose through SU and its a great hose but i had to make some modifiacations. I just installed my CPE FMIC and with the relocation of the BPV I deceided i needed a new hose because the stock hose was kinked after the install. When i started to install the hose i noticed it was to long so i cut it down to where i needed but I think its a perfect match for my set up. the only b**** about the install was to get to the inlet tube(Cobb) i had to take off the intake(Cobb) and reinstall the intake which is a b****... but an hour and a half( with the CPE FMIC pipe the routes over the BPV it is a b**** to reach anything to do with the BPV. My Forge BPV is hard as hell to change springs compared to the tmic...) I finally got it done and like every other mod i do thats a b**** i just forget about it and drive the hell out of my car.
I can't tell a difference with my tube but the stock one was so kinked up that i know it did something so i think the $20 is totallly worth it.
In short, yes. I have the same setup. Its as much as the SU hose but they give you three feet of it so you can make mistakes or split it with someone.
It will not kink due to the wire inside it. You just have to have some high torque shears to cut it.
