Bye bye turbo #2!!!
creedns
My 2nd stock k04 is roast big suprise. Might try and get it warrantied cuz mazda is finally admitting to bad turbos on everything before 08 but i'm more than a bit modified. If they won't its gt28 time. Too bad i'm not rich to afford that thing!!!
Cp-e nano short ram and turbo inlet, ngr type-s bpv, cobb front mount, mr. lil guy fuel pump, turbo xs tbe, one step colder plugs (big deal right), and a full accessport tune by surgeline tuning runnin 19psi. Weird cuz i don't smoke at idle only in higher gears when i hit boost and let off the throttle. But i jumped on the dyno at surgeline the other day did a pull in 4th and filled the place with smoke. They gave me a difinitive your turbo is ****** lol
yeah I would try thicker oil...Mazda has said they won't replace the turbo until they are sure that thicker oil doesn't stop the smoking
that suxxx, **** the 28, get the 3076 with a tubular manifold and external wastegate =] wit that and a good tune and ur beatin everythin on the streets, i seen one near me with that setup running like 7 0r 8psi and beetin bigturboed evos,, mad power
Haha for what i use this car for aka daily driving i don't need mad power. I'm bettin with a gt28 i can make 360-375 easy if i get it retuned. s*** on the stock k04 i made 317 at the wheels so i'm hopeful. But then i'll need a new clutch :( and i'm confident 5w-40 won't help me here lol its a TON of smoke that rolls out. I'm excited for bigger turbo but sad about the expense haha
^^^ nah they cheaped out on the motors as well
i have been blowing smoke at idle for the past 20k, i have gotten used to it. screw warrenty work.
yes because the smoking turbo means the engine sucks too. (hand)
The OP is fully bolted and running a tune at 19 psi. I'd only imagine it would be a matter of time before his turbo died.
Did you ever think of getting the turbo reworked yet?
Well, don't be pissed about that most turbo cars smoke a lil, mazda or not. Mine used to, it don't anymore..unless I punch it cause I have a CEL for too much fuel. Then it leaves a cloud lol. And I basically run open downpipe kinda but there is one cat, no ehxaust at all after the 1st cat.
bro **** the 28, get the 3076, it isnt that much bigger and spools maybe 500rpms later, trust me once ur car hits 3500 ur gonna be ****** outtt.. for teh price ur gonna spend on a 28, y not spend another couple hundred for a bigger and better turbo? just think of the sound of that wastegate wide open lol
Has anyone run a 3076 here on these boards without blowing for at least 5 months?? "my friend has a 10000 hp mazdaspeed" doesn't count. . .
3076 is risky business unforged
well, any turbo above stock is risky for an unforged motor. Hell, for some people the stock turbo tuned up is too much.
