Hey guys im burning oil. it was about a court low after 2,000 miles. The car has 100,600 and its a 02 mazda P5 lol. it has fully synthetic oil in it. the only mod is a cold air intake. and thats it. anyideas??
Can you smell it or see it or are you just assuming because you're low in oil?
Did this just start happening, or has it been doing it for awhile and did you change anything recently?
Could be any number of things, you might be running really lean and the computer is trying to compensate for it, could have a vacuum leak or a malfunctioning o2 sensor.
I was losing all my oil between changes. No smoke, no oil in the coolant, no drips...
I tried a new PCV valve, different oil, compression test and nothing solved it. Then just for a laugh I got a new filler cap. $6 whole dollars and 3 seconds to replace.
I've now driven over 20K and have no noticeable loss of oil between changes.
It could be a seal somewhere. I know for a fact that I am losing oil because I need to replace the oil pan seal, but it does not leak too bad. I also burn a little bit of oil because of my driving (drive). I have 110,000 miles and put in two quarts of 5w-30 synethic Quaker State every 3,000 miles (I usually change it at 3K or wait till 5K depending on situation). I might be doing the same on replacing my oil cap, but purely for comestics.
ho bag,
That is mainly because you have 60K on your motor, where as me and him have over 100K. I probably would burn little to no oil if i replaced that seal, but I just have not gotten around to it since it's so very, very, very little. Just to give you a tip, I did not change the timing belt till 103K miles. I also change the water pump, thermostat, and the hoses.
A lot of us experience some oil burning. Personally, depending on how I drive I can be as low as 1.5-2 qts in 2000 miles. I'm to the point now where I check my oil almost bi-weekly. So far I'm up to about 400 miles on this change with no major consumption. I should look into the oil cap thing though - would give me an excuse to buy a new oil cap .
