Broken Bushing Bolt
Speed3ForMe
2008.5 CWP Mazdaspeed 3
So as I was installing my TMW bushings, I over-torqued one of the bolts and it snapped in half, the other 3 is keeping the shifter plate/bracket in place very well.
How critical is it that I replace this bolt? The bushing wiggles very very slightly and won't fall out of the alignment and as far as I can tell, the entire plate/bracket is rock stable.
Should I replace it?
It will probably wallow out the bushing and eventually start to clunk. Do it now before its rusty and hard to get out.
I had the same problem. What I ended up doing was getting a pretty big drill and just drilling out the old bolt. I retapped the the floor pan with a slightly larger bolt, then I took my SU bushing and drilled it one out a little more to fit the new bolt. All in all, it took me 30 minutes plus a trip to Lowes for the new bolt. I put the new one in at the parking lot and drove off. Good luck bro.
