As an update, here is a listing of both the 3rd/4th gear variants that we carry and current stock levels:
8 x LASSS-3-124 (Synchromesh/Straight Cut/3rd Gear/1.24:1/Single Synchro/Std Bearing)
7 x LASSS-3-124-N (Synchromesh/Straight Cut/3rd Gear/1.24:1/Single Synchro/Needle Roller Bearing)
0 x LASSS-3-124-D (Synchromesh/Straight Cut/3rd Gear/1.24:1/Double Synchro/Std Bearing) ***
6 x LASSS-3-124-DN (Synchromesh/Straight Cut/3rd Gear/1.24:1/Double Synchro/Needle Roller Bearing)
0 x LASSS-4-090 (Synchromesh/Straight Cut/4th Gear/0.90:1/Single Synchro/Std Bearing) ***
4 x LASSS-4-090-N (Synchromesh/Straight Cut/4th Gear/0.90:1/Single Synchro/Needle Roller Bearing)
0 x LASSS-4-090-D (Synchromesh/Straight Cut/4th Gear/0.90:1/Double Synchro/Std Bearing) ***
0 x LASSS-4-090-DN (Synchromesh/Straight Cut/4th Gear/0.90:1/Double Synchro/Needle Roller Bearing) ***
*** All items with zero stock will be available within a 2 week period. Moving on from now, all stock for all models of all products will be replenished within a 2 week period.
We're also extending our standard gear breakage product warranty out to 12 months for all products sold from 2008 onwards from the previous 6 months, so customers can have total peace of mind. The only stipulations is professional installation and a good quality 100% synthetic GL-5, preferably GL-6 gear oil (synchro compatible for synchromesh products). Our only recommendation is NEO Synthetic 75w90HD or 75w90RHD gear oil which is made in the USA. Gear oil change intervals should be 10,000~15,000miles or every 12 months. Of course failure related to abusive and abnormal shifting (eg. flatshifting and gear synchro grinding) which may cause other parts of the transmission to fail, affect our products is not covered.
I've attached a picture of the reinforcement kit fitted to a G-Series housing.
