Broken 3rd gear x 3
Timing couldn't be worst for me Dino...maybe July or August, those are good month$ for me. I hope you sell them fast and you should but if you still have a set by then...like I told you before, I'm down.
so its recommended that 2nd, 3rd and 4th be changed right? $865 per pair with double syncros that comes to $2595 + shipping. Dont forget the lube, Add that on to what the shop is going to **** you with... for a grand total of...
3.2 million dollars!!!!
Kooldino has on hand 3rd & 4th sets which are the most commonly broken. 1st & 2nd gear are cut into the input shaft like stock so thats much more $$$$ See my pics a few pages back. It's really not too bad I'm sure it's less than your stereo setup!!!
Fifth gear pop maybe??
how do you know if you pop a gear my fifth gear has been hard to get in for the past few days like i have to almost slam it in at 3500 plus rpms
That's a synchro issue. If the gear was busted, it would make a terrible grinding noise all of a sudden, and it would be loud. You'd also never be able to get into that gear.
Also know that the tranny doesn't have to be pulled to fix your 5th gear problem. Just pull the wheel off and the fender liner to get the black cover off and there it is!
