Finished up another project I've been meaning to get to for a while. I've always wanted a dual gauge pod surround for a wideband and boost gauge, but whenever one popped up for sale i either didn't have the cash or the gauge placement was a little off.
lol so like everything else I've been posting lately I decided to make one. I used a spare cluster surround that I picked up for cheap and started to make cuts. If you ever decide to build your own a dremel or rotary tool is a must. It saved me HOURS of labor in cutting and sanding.
Both of my gauges fit snugly into a couple pieces of 2" PVC piping. I just eyeballed how much material to remove and went from there.
I then used some JB Weld plastic epoxy putty to mold/reinforce the PVC to the gauge surround. It turned out to be perfect for this project since it works well with both PVC and ABS plastic.
And then after a bit of sanding I added some wrinkle black paint to hide some of the uneven blemishes. (the paint looks uneven in this photo since it was still curing)
And the finished product. I still need to wire up the wideband lol
It definitely looks a lot cleaner than the old steering column pod. I'm also able to see the odometer again without stretching to look at it lol.
