1
181962
Turning off traction control ("TCS OFF" button) was discussed in some threads going back a year or two. Some drivers reported that it provides a feel somewhere between sport and normal modes, smoothing out the low gear shifting. Some also reported better fuel economy but that's a different subject.
I had tested this at the time and only noted that the gas pedal had a firmer feel, less pedal travel to get the same giddyup, but the shifting seemed to be about the same.
Now, after two months with the battery disconnected, I reconnected it and noticed no difference in feel but just for yucks I turned off the TCS. There is now a notable difference, much smoother in the low gears in normal, lower RPM driving, resolving the only real gripe I have with the vehicle--mild bumps or lugging in low gears situationally. I'll see how long this lasts.
So, if you don't like the low gear shifting try that--disconnect and reconnect the battery and then turn off TCS. This may not work with turbos or other model years but for one day so far it's a big improvement in my 2020 NA.
Of course you probably only want to turn the TCS off when driving on dry roads. You also have to remember to turn it off every time you start the car as it default to on at start up.
