Brake Problems
natestros420
2003 MAZDASPEED Protege Black 2.0 Dohc Turbo
would anyone know why when i come to a stop there is a loud clicking/popping noise coming from around the front left wheel? Also when i take right turns it makes the clicking noise but when i turn left it never makes the noise. I checked under my car to make sure there wasnt anything stuck near or around my wheel and i found nothing. If anyone has Any Ideas i would greatly appreciate it.
sounds like a wheel bearing problem or a ring and pinion, same thing happened to an old civic i had.
the noise sounds like its coming from around the brake caliper and rotor. but i still cant really pinpoint the origin. Would a warped rotor cause it to make that kind of sound or no??
yeah it could be , but the wheel bearings will make that noise then driving straight, the humming noise, when you turn it will to but i didnt know it would at low speeds like that, to test it, jack up your car and see if there is any play in your wheel, if there is its your bearings, and btw there a b**** to get out and in unless you have a press
yea i usually take the hub assembly off and take it like napa and have them press the old one out and new one in...mine did make to much noise when going straight but then again with my perrin exhaust i might not of been able to hear it lol..i took the hubs off and mine just fell out in pieces..
