Brake Light
J Goodz
Hiie,
My Brake Light lite's up every now and then. I'm not sure if it's the cold (NY its like 10 below here), the wiring or if I need new brake pads. I think that its the pads, i've had them over a year now. But If anyone else has the similar problem or have any idea what it might be lemme know. Thanx
-Joe
J Goodz
Did u chk ur b.oil level? because my buddy had the same problem (protege5) and kept on complaining, but when i chked the oil level it was below "low". the lights went off after we filled it up to "upper" level.
YES, check your break fluid reserviour....its certainly low....
and your brake pads should last you a lot longer than a year...that is unless you do a lot of autoX racing or something....or they see a lot of abnormal use.
