fourthmeal
Banned
		I have a question:
Did you or did you not turn off the DSC/TCS feature before you went racing?
The DSC button can be pressed before starting the car, effectively disabling all intervention systems, and presumably ABS. You'll know you've done it correctly because the traction light as well as the DSC light will be lit on your dash in yellow.
If this was pressed before racing, and you had to pull an emergency braking maneuver, this should force the computer into running like a standard brake system: which is to say that no brake-force distribution, no skid-control, no traction control, no yaw control, etc. At this point, the standard brakes (which are cross-linked for safety, in case a line is broken or other troubles) should pull the vehicle to a stop QUICK...perhaps skidding those slicks and eating a rotor, but it would have dropped anchor.
I know this is all terribly past-tense and I apologize for making assumptive questions after such an event, but honestly it could have saved the situation and I think you should know!
