First post and figured I would write up my brake and rotor change. Thanks to everyone who has posted before me. It really helped.
I was having the same issue with my OEM rotors. Brake pedal was pulsing and steering wheel was wobbly.
I used the Centric C-tek rotors 121.45080 and the Akebono ProAct 1258 pads.
In addition, I bought this Grabbit pro screw extractor and an impact screw driver. The impact screw driver worked to get 3/4 screws out, but I had to drill out the 4th. The Grabbit device was a life saver.
So, let's get to it.
I jacked up the car on weld points underneath the door. I put a jack stand underneath the unibody frame and the front cross member after I got the wheel off. Lug nuts are 21mm. For those of you who don't have an impact wrench, I had previously bought an electric impact wrench from Harbor Freight. It was $40 when on sale, plus the cost of the sockets. Here's what it looks like with the wheel off.
Once the wheel was off, I removed the caliper bolts. They're 17mm. The long one goes above, the shorter one below.
This is what the pads look like. Lots of life left on them - irritating. I debated about just getting the rotors resurfaced, but opted to go the more expensive route with the new rotors.
Onto the next post...
