Bose Info
6262MS3
I'm trying to round up as much info on the MS3 bose system as possible, it's part of a weird little plan I have to improve it until I have enough coin to buy an amp and front components. So far I've searched and found that the door mids are 6.5" and 2 ohms, the sub is 5 or 5.25" and 1 ohm, the tweets appear to be 0.5" and 4 ohms. Does anyone know what the power is for each channel? Only info I've found is 222w total power, which would maybe be 72w for the sub, 25w for each rear mid and 50w for each front mid/tweet combo, it would be nice to know the actual numbers. Also, is the eq roll-off done in the factory deck or in the amps?
Thanks in advance!
Hell that is a good ?, I might just have to call Bose today to find out.
