Bose Amp
Pavonis
Contributor
2007 Mazdaspeed 3
On the Bose amp under the drivers seat in the GT, does that have RCA outs? or just the remote wire, 12v and Ground?
no RCA on any part of the vehicle.
The amp would have:
+12v
Ground
Turn on
and all the speaker wires.
damn, as i have an old bazooka bass tube i was going to toss in there untill i have something better. Would the best way to just splice into the sub wires and tie them, or?
be careful. Bose is 2 ohms.
Doesn't matter for his application, he is just looking to get a signal.
Since you have the BOSE stereo you are in luck since you wont need to worry about large factory equalization. Although you "COULD" tap off the speaker wires for the factory sub... I would advise against it, because you don't know what the crossover slopes are on that signal, and it is DEFINITELY not a full range signal.
All you will need is a high quality Line Out Converter. You can tap into the wires behind the head unit (this is what I did for my install) or I suppose you could tap off the wires at the amp (I know someone else chose this method for convenience)
http://www.mazdas247.com/forum/showthread.php?t=123687372
read that for a lot more information.
On a second note; get rid of that bazooka tube.
