chillinmcmillan
- 2005 Premium White Pearl RSX Type-S
I can't wait to get my boost gauge installed and see what my boost is......then comes the boost controller(spin)
Ok, in the bold part. Do you mean you're not boosting when you are applying partial throttle? Like maybe 1/8 or 1/4? You have to keep applying more and more gas to keep the boost up, it will still fall a bit. Here's what works good in first gear, you just FLOOR IT!. In second apply 1/2 throttle and keep applying more and more till you hit redline, in third same thing, maybe a bit more gas.Speedmotion said:I just install my gauge last week, and the gauge reads no boost on first gear, boosting almost to 5 psi on 2nd gear, and little over 5 psi on all other gears then it drops back down. I also having hard time getting boost in 2nd gear, I rev it up past 4k rpm and I don't get boost, but sometime if I step on the gas pedal harder then I'll get boost on 2nd gear but the max it goes it's 5 psi, then it start to fall back down. It's this normal?? I got a custom bent cat back exhaust with HKS Carbon Ti muffler, and an Injen CAI.
