I'm going against the impossible and doing it. I've done the research and know it's best way to go. FInally got a great mechanic to help ( because I don't have all the tools).
SO here's my list of things I need!! It's a small list~
-FOrged rods and pistons (custom)
- ported head, gasket matched
- thumper kit wiht Gt 35R or GT30/40
- Bored intake manifold or switch (don't know yet still researching)
- bored throttle body
- 255lhp fuel pump
- A'pexi Power FC ecu ( i've seen it work wonders)
- fuel rail
- SARD fuel pressure regulator
- TUbular exhaust manifold (race spec)
- 550cc to 720cc primary injectors, 1,200cc secondary ( got off this months issue of superstreet)
- same side intercooler (easier for mounting but willing to go with standard)
- HKS surge tank
- 30mm or 40mm wastegate
- sport radiator
- stage 2 clutch
- brake booster
- springs/coilovers with 20.5 sway bar
parts installed (this is sad);
-brembo drillled slotted rotors........ um yeah woo hoo
-cel/mil eliminator
-flashed ecu
The only positive is that I have no expenses so I can spend nearly all my money on this car. I have yet to decideady yet wether to do camshaft/gears and pulleys. I don't think it will add much on what's already there on the list. Sigh... On the 15th I'm getting springs, exhaust 2.33", radiator. clutch?? July 1rst I will bore the throttle body and intake manifold, the fuel pump. July 15th should be the brake booster(still considering), fuel pressure regulator. Than the Turbo in september right before a car show.
- 255lhp fuel pump
- fuel rail
- HKS surge tank
- sport radiator
- stage 2 clutch
- brake booster
-cel/mil eliminator
-flashed ecu
