ok my spicy is consistantly inconsistant. some days it holds boost and some days it doesnt. well recently ( past week or two) is has been spiking to 8-10 pounds of boost then trickles down to 2-4 pounds. whats up with that? it has a solid 20-21 vac. i installed a forge WGA a year and a half ago and i just did the air test and its solid. what could be the problem?
I also have a CEL po455 (large evap leak). could that contribute to the problem? I think i found the source to that problem.. i found a hose that is orignally supposed to run to a black plastic cylinder on the passenger side engine bay, mounted to the firewall. the plastic nipple is broke off of the cylinder so the hose is running to nothing and there is just a hole in the cylinder. Im thinking thats the evap leak problem? and yes... my gas cap is on tight.
thanks for the help guys!
