Hello,
I decided to go ahead and perform a boost leak test. Bought all the hardware and built the tester. I removed the pipe going to the turbo inlet. Right there I saw the poor craftmanship of the turbo piping. There is a nipple that connects the cold pipe to the intake pipe to some valve, you should have seen the quality of that assemble. The nipple was glued on with crazy glue and sealed with black silicone smeared all over the place.....a friggin gong-show, I cannot believe Mazda would do stuff like that....of course it was cracked at the bottom....so I glued it back in place with epoxy glue and sealed it with silicone. People would say "change those plastic pipes", I won't because I want the car to remain stock to sell it. So that step completed, I pressure tested the system with a compressor at ~ 15 psi. Now this is weird, but I had air leaking from my oil stick! How could that be? I am puzzled...Anybody ever seen this?
Spooler
Spooler
