boost issue
voltz2049
Hi I just started experiencong a problem where my car will only push like 2-4 pounds vs before it always hit 4-5 idk what's wrong an ideas? Just threw cel like 2 days later only mods is intake thanks
Haven't been able to chec light jus happened b4 I got to work, is that the one by the turbo or the one by the intercooler piping? Thanks
what mods do you have done to your car?
waistegate is on the turbo it looks like a ufo with a vac line going to it from intake mani
I checked the wastgate, it seemed to be fine when i blew in the hose, the cel was gone when I went to start my car today? is it possible that maybe the tube that goes to the gauge from the vacum lines is cracked so it just reads as the boost dropping? im pretty new to this turbo stuff. Thanks for the replys
yes i would maybe replace that vac line going to your gauge cause maybe you like cut it when you put it through the firewall.. idk.. try replacing that..
